Networks: Remove Side
This is a text-only command.
Type the text equivalent at the command prompt to add a Network
The REMOVE SIDE command lets you remove entire spans from an existing wall network. Remember that a span is the length between each node. Nodes occur at all endpoints and/or intersections.
To remove a span, select [Draw > Walls > Remove side] from the menu:
  1. The prompt reads "Network to modify:". Select the actual span you wish to remove.
CC3 automatically removes the selected span and squares off the ends of the remaining segments in the network.
  1. The prompt reads "Network to modify:". You may continue selecting spans to remove, or right-click and select Done from the Walls popup menu to finish.
Text equivalent: NETRMV
Related topics
