Right click Text
to access Keep Text Height and Angle.
Use KEEP TEXT HEIGHT AND ANGLE to keep the height and angle specifications of the last text you added to the drawing. New text you draw will use those settings until you change them again.
For instance, if you insert text and place the text using the CTRL and CTRL+SHIFT keys to dynamically scale and rotate the text, using the this command would copy the text’s height and angle into the current settings
KEEPTHA works similarly to the KEEP command, except that the KEEP command copies all text and entity specifications to the current settings. KEEPTHA copies only the text height and angle, leaving other properties such as layer, color, font, and justification unchanged.
Note that you can extract the height, angle, and other text properties from an entity using KEEP.
Text equivalent: KEEPTHA
Related topics
