Undo
To undo an action, click Undo image\UNDO.gif.
CC3 includes a multi-level undo facility. At almost any point in your drawing, you can backtrack your steps until you reach the point of your last SAVE. Using the auto-repeat feature (click to repeat commands), you can sequentially see the effect of each undo.
To redo an UNDO (undo the UNDO), select REDO. Doing so will redo the last step undone. You can continue to redo until you reach the last draw/edit you performed. The REDO command only works if it immediately follows an UNDO command. For instance, if UNDO, draw a line, and then attempt a REDO, the REDO will have no effect.
Notes
Text equivalent: UNDO
Related Topics
