To redo an action, right-click Undo .
REDO will reverse the last command that was UNDOne. If a series of UNDOs have occured, you may continue to redo commands up to the initial UNDO by repeating the command.
Note: REDO only works if it is applied immediately after one or more UNDO commands. If another command besides REDO is invoked after an UNDO, a subsequent REDO will have no effect.
Text equivalent: REDO
Related Topics
