Click Trim to Entity
to trim entities.
TRIM TO ENTITY trims or extends selected entities to terminate cleanly at their intersections with a selected boundary entity.
The prompt reads "Select entity to trim to:". Pick a point on the boundary entity to which you will trim other entities.
The prompt reads "Select entity to trim:". The entity (or entities) you select will be trimmed to the previously chosen entity. CC3 allows you to continue to select entities to trim as needed. Right-click to end the command.
To restore the original entity:
Use the UNDO command (
Text equivalent: TRIMTO
Related Topics
