Node Edit
Click Node Edit image\DYNEDIT.gif to reshape individual entities.
The NODE EDIT command is a general-purpose command that lets you modify most entities one-at-a-time, using visual screen methods to modify them.
It is most commonly used to reshape polygons and paths used for coastlines, rivers and roads.
Because most dynamic edit instances utilize dynamic cursors (as indicated by the "|DynTrack|" prompt), the SHIFT, CTRL, and SHIFT+CTRL keys can often be used to expand your editing capabilities.
LINES
Re-positions the end.
Use SHIFT to re-position the anchor point.
CIRCLES
Changes the radius.
Use SHIFT to re-position the center point.
ARCS
Changes the endpoint (arc end angle).
Use CTRL to change the radius.
Use CTRL+SHIFT to rotate the start angle.
ELLIPSES & ELLIPTICAL ARCS
Re-positions the center point.
PATHS & POLYS
Re-positions any node.
Use INSERT or DELETE to add or remove nodes.
Use LEFT ARROW or RIGHT ARROW to cycle through nodes.
Right-click to terminate editing mode.
Smooth Paths & Smooth Polys
Re-positions any control point.
Use INSERT or DELETE to add or remove points (note that Bezier splines must have exactly four points).
Use LEFT ARROW or RIGHT ARROW to cycle through points.
TEXT
Re-positions.
Use CTRL to re-size.
Use SHIFT+CTRL to rotate.
Text equivalent: DYNEDIT
Related Topics
